Hi,
I bought one of these cases last month and all the review on the net pretty much say the same thing. "bottom up air flow", "silent design", etc.
I have the HS1 model which is now discontinued. All the reviews are on the HS2 model... The difference between HS2 is that it has place for 2 x 92mm fans, and the included fan blows directly on the GPU. The HS1 only has a 92mm fan at the bottom, blowing air in the direction of the power supply which is alot less useful imho.
The unit comes with a rear fan and a top fan over the cpu, theres an optional top fan and an optional bottom fan.
The thing is the 92mm fan on the HDD rack when set to "high" is noisy, so I'm not sure if I should replace it with a more silent one so i could have it set to high.
The only other positive intake fan would be on the bottom of the case. Should this fan have a super high CFM to compensate for the negative airflow by the 3 others (2 top and 1 rear)?
I was wondering if any fan experts could suggest a good setup for airflow on the HS1 ?
Thanks
Thanks
