thenixhex311
- Apr 30, 2005
I havent purchased these yet, but they are for my new upcoming system. The zalman has 4 connectors for the fan control, and it has 2 switches. I would ideally like these switches to control cold cathodes i plan on installing as well as some case feet.
One switch to turn on 2 cathodes, the other switch to toggle the case feet light on/off
I am by no means an electrician, but can figure things out. But on a scale of 1-10, how difficult would this be for a novice to hook up?
I know the back of the zalman where you hook up the cables for the switches you insert wire and screw it down. Is it as simple as taking the connectors off the ends of the cathodes/casefeet and plugging them in/screwing them down?
any light that could be shed would be helpful!
