let's see some pics
In pic # 4 you can see the two bottom fans, they are the only intake, then the Rad fans and the back fan are exhaust.
You should be OK with that PSU, w/o my SAS and with another GTX280 I was only pulling mid-high 400 watts at the wall. (that was with 700MHZ on the 280's and 3.6Ghz on the Q6600)
I did have to "re-engineer" the top of the case, so that the Rad would fit on the top. I hope that you have a dremelI'll take some more pics tonite.
Almost forgot, I cut out all the metal screen in the way of fans and it dropped the noise considerably.
So the holes on the rear of the case for tubing is useless? I was hoping the the rad would fit on there when I take the liquid plunge.
Your pictures don't work![]()
Nice looking case. But I like side-window to show off the parts.
host them at www.imageshack.us
Ok setup account....what URL do I post?
Nice pics! Anybody paint the inside?
