Zalman Fatal1ty FC-ZV9 on HIS X1950-PRO AGP
Does anyone know if the Fatal1ty FC-ZV9 will fit on the HIS X1950-PRO AGP? I bought an ICEQ3 model and the card is good but the fan makes a clicking noise. I'd RMA it but I can't be without a card that long so I want to put a Zalman on it (I had good luck with a VF700-CU on my old 6800GT). Also, would I be able to use some Zalman RAM sinks to cool the VRM module?
setscrew
Your answer is yes. Spend some time in this thread and you will find the information you seek. Post #465 by Johnny78 mentions the ZV9 specifically.
Thanks for the info. It was really useful and pertinent. I've decided to do the same thing to my card.
