Zalman CPU Coolers
PRIME1
Saw this over at www.techbargains.com, Amazon is selling Zalman coolers cheap.
http://www.amazon.com/exec/obidos/ASIN/B00032CWPQ/prime1-20?creative=327641&camp=14573&link_code=as1
Zalman CNPS7000B-AlCu P4, Skta, 754,939,940
$28.99
http://www.amazon.com/exec/obidos/ASIN/B0006VHVEQ/prime1-20?creative=327641&camp=14573&link_code=as1
Zalman CNPS7700-AlCu 478,SKTA,754,939,940, 775
$33.99
http://www.amazon.com/exec/obidos/ASIN/B0006VHVB4/prime1-20?creative=327641&camp=14573&link_code=as1
Zalman CNPS7000B-Cu P4, Skta, 754,939,940
$35.99
what do you guys prefer, the Zalman coolers or the XP-90? these are great prices, thinking about getting the alcu7700.
thanks
Nate
I have no experience with either, however I do have a cnps7000acu and its great. Usually people arent too thrilled about the zalman because the fan is built into the unit, where you have your choise of fan on the xp
Well considering you can't fit a 120mm fan on the xp90, i think the 7700 has better cooling potential.
you could always zip-tie it down. ;)
and actually if you shuffle through some reviews you'll see that that's not the case. It's definitely quieter though.
I have a 7700 and it idles around 34-36C and gets up to about 48-52C load. Not awesome temps but fairly good, and it's nice and quiet.
umbra said:
ah a modders best friend
And a mechanic's. If it moves and it shouldn't duct tape it......If it doesn't move and it should wd-40 it ;)
I ordered the 7700cu a few days ago thanks to this thread...
Now I have a 7000AlCu just sitting here NIB because I bought it at Fry's before I saw this thread. :p
You know what really sucks about Amazon is half the time when you order something they tell you AFTER you order it that it won't be shipped out till 3 weeks later. My 7700cu won't get shipped until like the 22nd according to my order status page. :mad:
Zalman is nice and quiet. Pair it with some good case ventilation and thermal paste, and you should be sitting pretty.
It took me over an hour to install my Zalman 7000B. Those are some nice prices, BTW.
Anyway, the reason it took me over an hour is because I was changing heatsinks. That meant I had to take out all my expansion cards, remove the motherboard, and install the backplate on first. If you're installing as part of a new build, it will only take a few minutes. But if you have to tear your computer apart, it could take some time.
I think the results were worth it, though. Nice and quiet and lower temperatures compared to the Thermaltake SilentBoost K8 I was running.
