defiant007
- Feb 27, 2006
So....I need to pick a new HSF for my C2D rig which I hope to build in January and would appreciate some [H] advice.
I intend to purchase an E6600 which I hope to over clock to over 3ghz. Am not sure what m/board I will be buying as I am still waiting to see what 680i boards Abit, MSI, DFI Lan and gigabyte have to offer.
Unfortunately I have not been able to find any reviews which compare these two monsters. From my research, it seems that the CNPS9700 is a monster, but suffers from the following drawbacks:
it is huge and therefore takes up a lot of m/board real estate (can anyone say whether it interferes with other components or results in an uncomfortably tight squeeze?);
again, it is huge and weighs enough to rip your socket out if you decide to move your case w/out dismounting the HSF;
the fan can be quite loud at the highest setting, in which case you need a fan controller or need to use the crappy included zalman voltage switch.
The Ultra 120 appeals to me because it is lighter, it has a high profile and therefore doesn't interfere with components in the immediate vicinity or cause the m/board to become too cramp, and you have the flexibility of using whatever fan you want with it. The most obvious downside is that its not made from copper like the CNPS9700 and therefore does not have as good cooling properties.
The fan that I would most likely use with the Ultra 120 is:
the 120mm scythe ninja (http://www.nintek.com.au/x/scripts/prodView.asp?idproduct=6669)
or
the 120mm Noctua (http://www.nintek.com.au/x/scripts/prodView.asp?idproduct=7662)
both of which are quieter than the fan on the CNPS9700.
Any opinions or advice are very welcome
or
