Hopefully someone who has this installed can answer a question for me.
Been sitting on a new build till now (holiday time). Started it yesterday. Put the backplate on the mobo (965p-ds3), put the clip support bracket on the front, put cpu in, added the zalman thermal grease, and put the S-type clip on (perpendicular to heat pipes) and screwed it down. Everything is tight and yet there is some minimal movement of the heatsink on the mobo. Not a rocking motion and its certainly not sloppy movement, but if I put my hand on the cooling fins and apply medium pressure in a twisting motion, I can get a couple of degrees movement left and right. Not up and down and not front to back, just when I twist. I removed it and tried rotating the S-clip 90 deg so it went across the heatsink (parallel to heat pipes) and the same movement is there.
Is this normal to have this kind of movement? Thanks...
