DeadByDawn
- Sep 3, 2004
I hooked up the fan and the power connector is a 3 pin connector.
The standard CPU fan connector on most mobos is a 4 pin.
Is this correct?
If you have one, how did you hook yours up.
I guess i can hook it up to another fan connector, but i wanted to use the cpu.
Thanks in advance.
Is this correct?
Thanks in advance.
