Zalman CNPS9500 Question
Funky_Junk
I just got the CNPS9500 and im ready to put it on my PSU. I want it to blow the air out of the back of the case, but im not sure which way to put it. For it to blow the air out of the back which way do I put it?
doesnt the documentation that comes with the heatsink state which way to put it?
it all depends on your cpu bracket.
if its horizontal you can have the fan blowing air to the back of the case
if the bracket it vertical then you should have the fan blowing towards the top of the case(and hopefully you have a blowhole)
the fan will spin counter clockwise...figure it out from there
