Zalman CNPS7000B-Cu
jokerx225
Hey guys im getting my Amd X2 4400+ tommorow and i just opened the heatsink i got for it which is the Zalman CNPS7000B-Cu. I was looking at the bottom of it and this is what i see... I tryed to clean it off with some artic clean and it didint come off. Does anyone know what the hell it is?
Don't worry about it looking dirty. It happens with copper sometimes, especially when you get it really hot (put a blow-torch on it and you'll see what I mean). This is left over from manufacture and will not effect the heat conductivity much, if at all.
yes, it should be a pretty well known fact that copper isn't exactly the most inert material. think of the statue of liberty.. it's green.. and made of copper ;)
