Zalman CNPS7000B-Cu
tailhook
I am using the retail heat sink and fan which comes with AMD's retail Cpu 3000+ Winchester This cooler and fan does not do that good of a job under load about 50c which isn't too bad but once the Cpu heats up to about 44c the fan is running real fast about 5850 rpm and it puts out a lot of noise and vibration So the biggest cooler I can stuff into the case I have is the Zalman CNPS7000B-Cu This one should keep it cool and eliminate the noise and vibration.. OK So how do you Like Zalman from what I read they are a good compamy Any thoughts on this cooler??
Thanks
J
Use the search function
Or go to www.google.com and search "7000B review" and you'll get all the input you need. And yes, it is a good cooler
Well, I was looking into this hsf too, did a search on forums for it, and the general consensus was its a great cooler, 7700 is out now, but its not quite as nice as the Thermalright XP-120. One guy also complained the weight of the Zalman possibly hurt his mobo. Well, personally, I think Im gonna go xp-120..
I also like the Thermalright XP-120 but I can't fit it into my case do to the height I,m cutting it close with Zalman CNPS7000B-Cu the 7700 is 5mm taller which i may be able to get that one in but I probably would be almost against the power suply So ordered the CNPS7000B-Cu Only thing i don't like about this setup is that I will have to remove the motherboard to install this cooler on the A8V Asus Much easier to find a clloer that just snaps rite on..I should hve put some thought into my setup before trying to use the retail cooler that comes with the retail Cpu
Cheers
J
how heavy are these things? I just bought the 7000b-cu(all copper) as well, anything I have to look out for with such a heavy HSF? or are people just exaggerating??
