Zalman CNPS7000A-Cu
papa_otter
Hey all does anyone know if this heatsink will fit on an Asus P4P800-E deluxe? Been wanting to get one, or any for that matter, but the memory controller heatsink just below it is damn close with the stock one on. So has anyone tried this yet?
-edit- and if not have you found one that worked.
It should work without a problem. What you need to be worried about is the clearance between the top of the motherboard and the bottom of the PSU. You need some room between the two, as the big Zalman heatsink hangs over the edge of the board.
