FreshPrinceOfBellAir
- Jul 7, 2005
Edit: Ignore this it wont fit
Has anyone installed a ZALMAN CNPS7700-CU 120mm on a DFI LANPARTY UT nF4 Ultra-D . I would like to do this, but the MoBo is not listed on the "works with" list @Zalman. The pics make it look like ths heatsink might be too close to the memory. I'm going to use value ram so it's not abnormally tall or anything. Maybe I should just go with the 92mm version? Thanks
