Zalman 9700 kicks ass!
Z
Zinn
Guest
I got this thing loading my C2D e6300@3.33ghz at 49C
That's with 2 x Prime95 loading the CPU 100%, the fan is on medium speed (2030 RPM) and barely audible. I'm impressed.
Oh and the damn thing is so sexy it makes me [H]ard. I would totally recommend this thing, especially since it costs less on Newegg than the CNPS9500.
I don't really have that stuff. I just put it in my sig to make it look like I have a cooler PC!
Actually my camera is charging. I will be sure to let you know first as soon as I take a pic with the 8800 in it. The Audigy is barely visible in the existing pic underneath the PCI slot blower. Look at what its cable is running along.
BTW how's the 3.2ghz OC going on that X2?
i love my 9700. I can beleive how well it cools. It had been a while since i built a air cooling system...
It LOVES the fans I installed in the case window.
Before I installed the 2 s-flexes in the window...
it kept my fx-55 running at oc'ed from 2.6 to 2.9, and 1.492 volts at:
System temp: 28
CPU idle: 32C
100% load 10 hours of prime95: 40C
After I installed the window fans:
System temp 27C
CPU idle: 28C
Load: 35C
This cooler works really well, and that with the fan only on Medium (about 9 volts on my fan controller) becuase you still cant hear it. At 12V you definately can hear it out side the case... and you only gain about 1C at load, so it wasn't worth it to me.
Slap me impressed as well.
Using the 9700NT with similar results (same HSF, but silvery in color with a green LED).
yeah i wish i got that one... but when i got mine, it was nowhere in stock, then like 2 weeks later, 3-4 places had it!!!!
Ah well, what can you do, i still love it!
