D
Deleted member 169154
Guest
I want to upgrade my current CPU. I have the Zalman 9500 already installed. If I remove the heatsink itself (not the mounting brackets) and replace the CPU and then reinstall the heatsink, is it possible to do this while still leaving it in the case? I seem to recall an excessive amount of force needed to get the screws down on the heatsink.
