Zalman 9500?
Does the Zalman 9500 LED fit comfortably in aa Intel BOXD975XBXLKR? I've been trying to decide on a new heatsink for my Core 2 Duo E6400 so I can get a pretty decent OC. I was considering the Zalman 9500 or a Big Typhoon VX, the new model. I am assuming the new model with fit since the old version of the Typhoon does..I believe they carry the same dimensions as well. If someone could confirm this, that'd be great. I may consider a mini typhoon too; although, I wouldn't be able to overclock as well then.. However, I'm not really certain if either will fit in this motherboard? Can anyone with experience lend a hand?
Oh, should I be concerned about the weight factor of the Big Typhoon either, if I was to get that cooler? 800g seems real heavy..Any other advice..Go right ahead. Thanks.
Here's a link to the motherboard: Intel BOXD975XBX
Again, thanks.
