I have an IHS-less opteron 146 at 2.6ghz and a zalman 9500 cooler at full speed. when i check the contact with the core the thermal paste is very thin where the core is and you can see it has been squeezed out by the contact. now i would assume this means my cooler has good contact with the core, is this correct? however and this is the problem, my temps at the moment are 35 idle and 48 load. this seems way too high for me at this clock speed and with this cooler.
now obviously the thermal paste hasn't had chance to settle yet so this may be premature and the temps will all drop by 5-7 degrees, but i doubt it! anyway, my question is this. does it sound like my HSF is making good contact with the core, if yes why are my temps like that and how do i make them better?
if it indicates bad contact, how do i make it better?
i should point out that i have sanded down the socket mount (took off a chunk the same thickness as the ihs) i have also tried this with my case side on and off - temps same both times. my case fans are 1 vantec tornado and an akasa 80mm silent exhaust, 3 80mm akasa silent intakes at front bottom, and 1 vantec tornado over the zalman. my case is the raidmax cobra.
any help is much appreciated
thanks
daven
thanks
daven
