jcll2002 said:will i have to remove the mobo to do this? I dont have to install anything onto the back according to the manual.
What steps do i take to remove the mobo?
Thanks,
jcl
so that means i will have to remove it in the first place?amd ati FO SHO said:Take out pci-e card, pci cards, etc.
Remove necessary cables.
Remove screws that secure motherboard.
With that motherboard you should be able to use the oem backplate, which would save you the trouble of taking motherboard out.
yeah thats what i was thinking...just wanted to confirm that i could do it w/o breaking something and if it would be the easiest wayburningrave101 said:You shouldn't need to remove anything other then what it takes to get access to the CPU socket area. Just take out the two screws in your CPU retention on your board and install the Zalman 9500.
