A Shiny Demon
- Oct 18, 2006
I just reworked the setup in my sig (Abit IP35 Pro and Zalman cnps7700-cu) and noticed that I could actually lift the Zalman off the surface of the CPU just by tugging on it, and I wasn't even pulling very hard. I have it set to ramp up according to the CPU temp, and the CPU stays around 45C but the fan is fairly noisy too. (Although my sig shows a 50% overclock, I've backed it down to stock 2.0GHz and it's running on the lowest voltage the BIOS will let me pick).
Is the Zalman too loose, and is there a way to fix that? It's screwed down tight.
