just wondering the difference between the 7000, 7000A, and the 7000B. All I can find is that the B has less surface area and 15g less material, also has a fan mate 2. Am I missing somthing?
off the top of my head 7000 = all copper while the 7000A is copper and aluminum. also i think one can fit on either amd xp or intel boads and the other can fit on amd 64, xp, and p4 boards. i could be wrong, can anyone clarify?
I probbly should have specified I meant revisions I know the 7000cu is all copper and the 7000alcu is only part copper but there are 3 versions of each I am in terested in the copper versions and the difference between each revision. 7000cu, 7000Acu, and 7000Bcu.
