Zalman 700AlCu GPU
DangerIsGo
If i want to OC my gfx card, how well does this cooler perform? Remembering I have an XP-120 right above it, so the TR heatpipe (I think its the X-1? I forgot) cooler probably wont fit, and itll be too much heat in that area. What are some OC's you guys have had and temps (idle/load) to go with it? Right now its 510/1350 getting 8450 in 3dmark05. I want to go higher, but what do you guys think? Is there much difference between the Cu and the AlCu? Right now, idle temp is around 45-50C while load is about 68-75
