Zalman 7000a and b?
Karandras
What is the big difference between the 7000A and B? (I'm thinking I'm going to get the B-LED version) I'm just curious.
A is the older version and B is the newer revision...I guess the performance should be better? I don't know I have the revision A (thats not sold anymore)
The only difference that i ever saw was that the A version has a stupid metal backplate that just LOVES to short on motherboards (had this problem first hand) and the B uses a plastic backplate.
Ah you're scaring me :eek: I just started using it when I switched to 939 mobo
