Zalman 7000 temps
Render
i have a sandiego 3700+ with 1.5 vcore @ 2.7
my temps are 33 degrees C idle and around 48 degrees C load
my questions:
1. Are these temp high?
2. will say an xp-120 or si lows the temps?
3. I know my cpu has more in it, since ive hit 2.85 on 1.535 vcore, but the temps go over 50, which is a bit warm, so should i get a new air cooler or go water cooling.
thanks
my questions:
thanks
Sounds spot on, depending on your ambient temps....
