Zacate summer time temps
tikiman2012
So what has everybody's zacate been running at 4 a temp when it's 90 degrees outside. Mine was running at 74c while in use in a Habey 800 case.
if I knew a way to determine the temp on mine (its running solaris 11) then I would post it
Mine running at 70c idle on XBMC home and 60c while playing video
I ditched the habey for a wesena case and my temps dropped 10c at full use (only a couple at idle) down to 42/60c (mainly due to the 80mm fan pointing at the massive heatsink)
Those Wesena cases are sweet. I would love to swap out the Habey. Unfortunately the wife would give me a swift kick if I went and bought a different one now. :eek:
yeah, I took my swift kick and tried to pretend it didn't hurt, lol (only reason she pulled the kick a little bit is that the WAF is so high on the wesena, also b/c I got all the media center add ins working at the same time so it is super easy to use now)
