Z790-E Ram Issue
oMek
Hello all,
Just built a new system for the first time in 6+ years. I am having a really hard time getting the memory to run at XMP 1, 2, or Tweaked. The sticks are installed in A2/B2 slots.
If I turn XMP on an turn the speed down to 7000 they run memtest86 fine and do not error for hours. If running default XMP they error and also cause BSOD's. Could this be a MB or IMC issue? or do I just have some settings wrong. I noticed some beta bios where posted not sure if I should give them a shot.
Thanks for any advise you can offer.
13700k
Asus Z790-E (0904 Bios)
Gskill DDR5 7200 (F5-7200J3445G16GX2-TZ5RK)
The 0904 bios is the latest one.
When you set the default XMP which is 7200 c34, do you set other settings (vddio, mc, txvdd, vddtq) manually or you leave it auto?
If auto, then I recommend you to set them manually, especially the MC and txvdd/vddtq one.
Running 7200 c34 is not very hard for Raptor chip but any XMP things on 7200 and up will require further settings on mobo's voltages.
