probably just PCI-E 3.0 (if you can make a good use of it).
best reason to upgrade....you like throwing money away!
Nobody can. Not even in the next three years; cards today don't even get close to saturating PCIe 2.1 x8, let alone x16. Doubling that speed makes zero improvement in performance; the only benefit might be next-gen high-end Quadro/FirePro and Tesla graphics cards.
I was thinking about PCI-E SSD actually.
But, I reckon, if all the modern cards go PCI 3.0, you will need that board for your next upgrade.
If you've got a decent functioning Z68 board, there's definitely no reason to upgrade boards. So far early reports from CES show that manufacturers are using fewer/weaker power phases with the Panther Point boards since the Ivy Bridge chips have lower power requirements.So is native USB 3.0 it? Just wondering if there will be a reason for Z68 owners to bother upgrading their motherboards.... assuming it's IB compatible.
.. but i'm sure that will require you to have an IB chip as well...
Ditto with the latest round of Gigabyte Z68 boards, the one I just picked up supports pci-e 3 native with "next gen 22nm CPUs" I'm guessing means IBWell if you have Asus Gen3 board I see no reason to upgrade.
You can stick IB in that and use PCI-e 3 GPU
