z77 NDA lifted!
Discussion in 'Intel MoBos' started by NICKSTAR, Apr 8, 2012.
  1. Soulmetzger
    Soulmetzger [H]ard|Gawd
    1,173
    Aug 10, 2004
    Boom goes the dynamite!
  2. striker444
    striker444 Limp Gawd
    497
    Jan 20, 2012
    Interesting to see that some support DDR3 2800 RAM, now Newegg just needs to start selling it highest I see is DDR3 2600
  3. SonDa5
    SonDa5 [H]ardness Supreme
    7,379
    Aug 20, 2008
    I have seen the "older" DDR3 do fine with the new chipset and IB cpu, There are many benchmarks online if you search for them.
    IB is the power behind the high speed DDR3.
  4. SKL1
    SKL1 [H]ard|Gawd
    1,032
    May 25, 2006
    Ill wait for EVGA's board...don't really like the look of any of those.
  5. Melon
    Melon [H]ard|Gawd
    1,169
    Jan 8, 2012
  6. bastage
    bastage Pics of your wife?
    12,761
    Mar 4, 2010
    So its nothing major, but what I like is that all the lower end boards have a front panel USB 3.0 header. This is not the case with z68 boards.
  7. 4LC4PON3
    4LC4PON3 DERP!
    4,234
    Jan 18, 2005
    I for myself just cannot find any good reason to switch from my current asrock extreme3 gen3 board to go to the new Z77. I guess I am saving my money
  8. SKL1
    SKL1 [H]ard|Gawd
    1,032
    May 25, 2006
    Evga here http://www.evga.com/articles/00677/ ...too much $$$ for me, I hope they have a cheaper SLi board like they did with P67 and Z68, I really want the first two PCI-E slot to 3.0 though.
    The ASRock Z77 Professional is looking pretty good too me right now.
  9. gsilver
    gsilver Limp Gawd
    402
    Oct 12, 2010
    On the lookout for a Maximus V Gene. I'm going mATX this time around, and I need a good Wifi option, so the mPCI-e slot sealed the deal.
    I see a few from stores that I've never heard of, but they have yet to show up from "the usual suspects", and I suspect that they'll be cheaper once they show up there.
  10. youghmama
    youghmama [H]Lite
    104
    Mar 24, 2012
    +1 The ripoff factor on the aftermarket USB 3.0 front plate headers is pretty high right now, so, even though I don't need it yet, that front 3.0 header plate will be great as my case didnt come with one.
  11. crazyg0od33
    crazyg0od33 n00bie
    41
    Mar 4, 2012
    I set myself a budget of $350 for the motherboard, and I really like the features on the evga, so evga it is this time around I believe
  12. MissJ84
    MissJ84 2[H]4U
    2,050
    Dec 22, 2009
    I think we'll see the H77 itx boards soon, but it''ll probably be awhile until the Z77 itx boards show up :(
  13. burningrave101
    burningrave101 [H]ardForum Junkie
    11,836
    Sep 9, 2003
    I may give EVGA another shot and check out the Z77 FTW if ASUS doesn't come out with a Maximus V Extreme pretty soon. I'm kind of put off by their Formula board this time and that stupid waterblock they thought it needed. Although I'm also not liking the fact that EVGA decided not to include at least a DisplayPort out on their board when one of the biggest improvements of Ivy Bridge is the iGPU performance. Just because most high-end board users have a dedicated graphics card doesn't mean they wouldn't use the option of the iGPU as a backup for those times when you need to RMA or if you want to sell your video card in anticipation of the soon to be released next gen from nVida and AMD.
  14. NICKSTAR
    NICKSTAR 2[H]4U
    3,924
    Jan 18, 2009
    i guess im going to bite on a cheapo h67 to get me by til the z77 itx comes out.
  15. Rattle
    Rattle 2[H]4U
    2,573
    Apr 10, 2007
    $240 for sabertooth not bad, I make it a habit of not spending more than $200 on a mobo usually.
  16. Vithar
    Vithar Limp Gawd
    263
    Mar 6, 2012
    I'd like to see boards with 5 4-pin fan pwm fan headers for under $200, such as the EVGA Z68 SLI, till then all the boards on here are junk to me.
  17. JacobC1983
    JacobC1983 2[H]4U
    2,547
    Sep 4, 2006
    EVGA z77 FTW board has a mini display port. It's on the spec sheet
  18. burningrave101
    11,836
    Sep 9, 2003
    Oh does it? I didn't see video out mentioned on the product order page and when I glanced at the boards photos thought that small port was just for something else. The EVGA z77 FTW is sounding better already :).
  19. ManofGod
    ManofGod [H]ardness Supreme
    6,705
    Oct 4, 2007
    Am I missing something or do all those listed boards not have true 2 x PCI 16 configs? I see 16x, 4x or one board that is 8x, 4x.
  20. limitedaccess
    limitedaccess [H]ardness Supreme
    7,395
    May 10, 2010
    Same deal as SB LGA1155. You'll need to move up to LGA2011 if you want more native PCIe lanes or Quad Channel Memory.
  21. RamonGTP
    RamonGTP [H]ardness Supreme
    6,853
    Nov 9, 2005
    That's the one I'm looking at out if Neweggs current offerings. I want the Asus P8Z77-V Pro but newegg doesn't have that yet. I'll be checking Frys after work tomorrow.
  22. Synomenon
    Synomenon [H]ardness Supreme
    6,993
    Feb 10, 2007
    Wait, there was a NDA? I've been seeing Z77 boards at my local Fry's for the past two weeks...
  23. RamonGTP
    6,853
    Nov 9, 2005
    Did you actually see the boards? My local Frys had tags up but no actual product.
  24. Crazy Chuckster
    Crazy Chuckster 2[H]4U
    3,026
    Oct 6, 2001
    I will wait for reviews but Kyle has mentioned in a z77 preview that there will be little reason to switch from z68 to z77
  25. Synomenon
    6,993
    Feb 10, 2007
    Yes, the actual boards have been on the shelf for the past two weeks.
  26. BusyBeaverHP
    BusyBeaverHP Limp Gawd
    413
    Jun 22, 2009
    Snatched my ASUS P8Z77-V Deluxe. All that's left is April 29th.
