z5500 problem
Matisto25
Hey i have the same problem as this guy http://hardforum.com/showthread.php?t=1389067 when i want to enable digital dts in creative software and use spdif passthrough it doesn't work i can't use them both ? somebody have solution for this
I always need to disable the encoder to off in creative software :( then passthrough work but then the sound doesn't come up after few seconds in the beginning and also if you pause (z5500 problem?) it's annoying so i want to use digital dts in software already
i use default playback device spdif-out in windows and also in my media player to play the video file
