Z5500 Front Speakers..
jayx9
I bought the z5500 set something like a year ago and everything was alright. Lately it seems the fronts speakers are considerably lower(in terms of sound output) than the back speakers. Naturally I checked all my sound card settings and connections on the speakers physically and didnt find anything wrong. Have any of you guys with the same set had the same problem and possibly a fix?
Thanks.
I've heard logitech is pretty good about customer service. If you bother them about it you may get a replacement.
switch the speakers - front to the back and vice versa and test again
z5500 have 2 yrs warranty on them ... get them replaced if there is some problem
Ive tried switching the backs with the fronts and the sound output is the same(low) so I dont think its the speakers...
dude you probably have the surround level all the way up which would increase the sound levels of your back speakers. turn the surround down a bit and your fronts and backs should even out
