Z5500 for game console
exe163
how can i connect my game consoles ( NGC, PS2 XB XB360 ) to my logitech z 5500?
You could use an optical cable, but you'll only be able to connect one system at a time.
THe creative DDTS-100 lets you connect 3 optical, a coaxial, and 3 analog and swap between them.
Im sure it would work with the logitech speakers too - assumign its got the same 3 connectors? front left/right back left/right and centre/sub
O yeah, i almost for got there's 2 holes(white and red) on my controll panel cames with my X-Fi sound card (Fatal1ty) My Dell 2405's back have some holes for Video input. so If I wants to play in can i plug the console into my monitor and my controll panel (computer)? can 2 color pins on the console able to use 5.1? and is there any swiches(sound) b/t my computer and my console for cheap ?
no, the rca jacks will only allow for stereo sound. Your 5500's offer connections for both optical and digital coax. Which system do you have?
I have a stinky gamecube now planning to get a xbox 360 or PS3, just wants to make sure if they can be play it using my computer monitor and speaker or not, b/c my computer have higher resolution and 5.1 surround system that my tv dont
