Z-5500 and wall/ceiling mounting
Swarley
I bit on the great amazon Z-5500 deal earlier this week and they should be arriving on Monday. I want to mount the front and rear spears on the wall but while I haven't personally looked at the bases the speakers come with they don't look that great for what I want to do and most if not all reviews say they're not that great.
With the way I want to mount the speakers I would have to somehow mount them in a corner to give me the right directions but with those bases I just don't know how well that will work.
My question is am I worrying to much about them, will they work fine being mounted in corners? And if not can I get some home theater wall/ceiling mounts and somehow get them to work with the Z-5500 speakers?
You can get mounts for them, but you have to pull the speakers apart to remove the stock base.
It's a bit of a pain, but definitely doable! I have my rears mounted on stands because I didn't have anywhere to set them.
Good to hear! Can anyone tell me a good place to buy satellite mounts online? So far from what I've found I'll be paying about $12ea, any better deals out there?
