Great, glad to hear it. One of the challenges of this project was moving through different languages: HTML, CSS, and ASP on the website, SQL, and C++. Your team number is larger than 2**15, and I had used CINT() in VBScript to convert it to a number because I think an integer is 32 bits wide, so that's what caused the script to fall over when you tried to register.Hades12 said:We got one of mine working. Will start adding more machines.
Strikemaster said:Quick skim of the docs shows it doesn't monitor remote machines. Limitation of Windows share function, Samba, or is it more along the lines of machine ID mixing? At any rate, if it passes, you get all the crates I have in Boomerhaus and at the office.
Strikemaster said:
From what I understand it scans the speed during the initial install (or therea a bouts) and records that in the database. There's no support for dynamic clock speeds, I hope soon tho.drizzt81 said:How does it deal with the dynamic clockspeed of my Pentium M proc?
Things that nobody has ever asked for are very unlikely to be supported.dekard said:There's no support for dynamic clock speeds, I hope soon tho.
my concern was that my Pentium M does change its clockspeed every once in a while. I had it downclocked to a 12x multi recently (even on AC) and now I have it back up to a 15x multi. I guess I need to re-register it?mikeblas said:Things that nobody has ever asked for are very unlikely to be supported.
How would you imagine this support to work, meanwhile?
Almost any machine can change its clock speed at any time. Processors downshift to throttle for heat or power saving or noise. The Pentium M chips do it for battery life.drizzt81 said:my concern was that my Pentium M does change its clockspeed every once in a while. I had it downclocked to a 12x multi recently (even on AC) and now I have it back up to a 15x multi. I guess I need to re-register it?
I'm far more interested in deleting machines that have registered and haven't produced anything.MaoKhan said:question: why would one delete old computers that aren't producing anymore? i'm assuming the information gathered is still saved, just actual computers?
Well, I'm open to convincing. It's not like query perf or space is a problem so far.MaoKhan said:ah makes sense, carry on![]()
I'm not sure how a batch file would be simpler than typing "yurtmonitor install". What is it that you would want the batch file to do? What does your file do?roftranspo said:Maybe a quick batch file that comes with YURT to install it as a services. I made a quick one for myself to make installing quicker. Just a thought. and yea...you did do a great job on it. I keep forgetting that it is even installed![]()
pretty much....my just went:KodiakStar said:I'm guessing it's just something you click on in the directory that YURT stuff is un-zipped too, double click and it does the whole cmd :\ yurt install stuff all in one go
mikeblas said:Almost any machine can change its clock speed at any time. Processors downshift to throttle for heat or power saving or noise. The Pentium M chips do it for battery life.
But why does it matter to YURT? The numbers collected aren't involved in any math; they're just shown on the machine details. Since the clock speed can change very frequently, there's no good way to historize it.
If you don't like the speed that's shown for your machine, just reregister. Doing so won't wipe out your previous work and will override the old clock speed (and memory, and so on) with your current values.
No offense taken at all.drizzt81 said:First off: I was not trying to critizise your work. I greatly appreciated it.
It's not really poisoning, since the clock speed can't be that dramatically off. Also, since we don't know what users are doing with the machine, the cycles the folding process has available to it vary greatly. A couple of my machines are almost completely idle; others are development and test server machines that are heavily loaded whenever I'm in front of 'em. FAH might be getting 0% CPU for hours at a time on those rigs. There's just no realistic way to measure it or historize it.drizzt81 said:I understand that saving a history would be difficult, I was asking, since I was under the impression that yurt was partially intended to provide statistics on how quickly certain cores were able to complete work. I did not want to poison the source data. I will re-register my laptop tomorrow, when it'll be back in use.
Depending on what statisitics are to be collected and for what reason, there would always be the option to "weigh" the data with repect to the time it was added to the DB. More recent data in the DB would have a greatest influence on the expected output from a certian processor while older data would be incorporated but at a lesser weight. Then again, it is probably easier and less computationally expensive to just delete the records.mikeblas said:Well, I'm open to convincing. It's not like query perf or space is a problem so far.
Slightly different topic, since you mentioned it: CPU time usage.mikeblas said:It's not really poisoning, since the clock speed can't be that dramatically off. Also, since we don't know what users are doing with the machine, the cycles the folding process has available to it vary greatly. A couple of my machines are almost completely idle; others are development and test server machines that are heavily loaded whenever I'm in front of 'em. FAH might be getting 0% CPU for hours at a time on those rigs. There's just no realistic way to measure it or historize it.
Which page do you mean? After all, they all have stats!ElektronikSeraph said:Looking around the stats page... is it possible to get an average PPD? I see it's listed for each individual protein (or frame), but it'd be nice to see what each machine puts out on average... so I can see how my machines stack up.
mikeblas said:Which page do you mean? After all, they all have stats!
Celerator said:mike,
Why on the Machine page does it not show frames for all proteins, or the current protein?
I only seem to have frame stats for the first protein YURT tracked and no others.
I can add it, it shouldn't be too hard.ElektronikSeraph said:Well I was kind of expecting to see average PPD on a Machine Details page, at the bottom of the PPD column - like where the Totals are listed for Protein IDs, Work Units, etc.
It's not stupid; just really vauge. Since I'm not psychic, I'm bad at guessing games and have to ask.ElektronikSeraph said:EDIT: Guess it was kind of stupid of me to not specify, lol. Sorry about that.
mikeblas said:I can add it, it shouldn't be too hard.
I've run the scripts to nuke machines which haven't ever submitted work for more than a month. That knocked us down to 202 machines from 208.ICE_9 said:Congratulations YURT on reaching 200+ registered machines!!!![]()
