YS Tech TMD Fan??
amohedas
I have an SLK 900A and I was wondering if I would experience a performance boost (in cooling of course) if I were to use a YS Tech TMD Fan. Right now I have a good 'ol coolermaster led fan. Its 80mm and blows about 34 cfm, and very quiet. The reason I ask is because the 80 mm coolermaster has a large dead spot right in the middle (like most fans) and that is exactly were the core is......so I was thinking with a YS tech fan I might be able to get better performance since it has a much smaller dead spot.
I have also read that they have issues with shorting out, but it seems more like user error to me.
I was also wondering about the noise levels on these fans.
Thx
LINKY
They are by no means quiet fans but if you wanna know if you'll be seeing improvements then YES.
i have one that i could sell to you - it's brand new, with sleeved cable (black expandable sleeving with black heatshrink).
btw, it's pretty quiet - although the DBA rating is higher than quiet fans, the noise is very low-key. looks cool, too.
PM me. this is the 36cfm version. will sell it cheap. :D
PM me or email me at iv@codeflux.com and i will email you a photo. this is the 36cfm version. will sell it cheap. :D
that is the one thing about them. They're not quiet at all but the noise they make is very "low key" as codeflux said. Sry I left that out. ;)
