FuzzyPoncho
- Oct 19, 2006
Ok, I've gotten some negative feedback on using HTPC with a wireless network for streaming content (videos, music, etc) What I plan on doing is getting a Draft-N router to increase the speed (mostly for HD content). Right now im using a Standard Linksys Cable Gateway, getting "good" (so approx 36mbps) connection.
As it stands it right now it takes forever for my HTPC to even sort through my video library (alot of lag, delaying reaction) When playing a file, it randomly stops the video and I have to restart.
Now I tested the computer on a wired network and works fine, so I know its not the unit itself
I need some feedback on wireless setups and if anyone has had issues with using Draft-N to stream to the HTPC, or maybeI should try to find a wired solution? This setup wouldnt be cheap so I would like to know what Im getting myself into..
Thanks
P.S.
My HTPC is listed below if anyone is intrested...
HTPC
LC10 Silverstone ATX
Core 2 Duo E6600 FSB 1400
nForce 590 SLI
1x 250 Western Digital
2 gig Gskill 800Mhz (dual channel)
Evga 8600GT HTPC
500W Rocketfish PSU
Thanks
P.S.
HTPC
nForce 590 SLI
Evga 8600GT HTPC
500W Rocketfish PSU
