t-readyroc
- May 15, 2002
I got a 60mm -> 80mm fan adapter for an old hsf a while back, & ended up using the screws on my AX7 a bit later on. Well, now I need to buy replacement screws. Problem is, I can't find the f*%@kers anywhere. I've tried the local Lowe's & Ace to no avail. I also just got done Googling & searching through these forums w/no luck.
What I'm looking for: #4 1 1/4" pan head sheet metal screws
So I figured I'd post & see if my luck improved. Any of you guys got a source for the odd screw that you need for your project(s)?
