Your overclocking settings PLEASE
wassup61
This is going to be my first time overclocking.
I am using EVGA NF41 and an opteron 148 CABYE.
What mem settings should i use/ fsb... youre best modest guess for 2.8 ghz
Ram is G.SKILL Extreme Series 2GB PC3200
Jeff
Read those already. There are so many settings that seem to be in the bios that arent explained. Also... which slots are the dual channel slots in the NF41 Mobo... are they the yellow or blue ones. TIA
Jeff
For that, consult your m/b manual.
Anyway, the only think you'll need is to upp the FSB, front side bus, by incraments until your ocmputer doesnt post...then loosen timeimings, upp voltage on the ram or maybe processor and continue over...The point of o/cing it to do one variable at a time to max out the overall potential off your proceessor. After you think one variable is good, start to change another one. It's a constant troubleshoot and it takes time. You won't get 2.7 overnight, well shit, you just may...good luck
Don't forget: It takes a little while for the CPU to burn in. The CPU max can increase over time.
-J.
