Most bartons have a maximum operating temerature of only 75°C, no?FLECOM said:that is hot as a mofo, i dont know that much about nvidia cards but 81C will kill an athlon after 30 days probably too
Lunas said:i believe silicon breaks down at 90c most chips last till 75-80c so yes i would say the heat is what is frying all these GT's
No. The default "core slowdown threshold" temperature on the NV40 is 120C. That's the temperature that those chips are designed to handle.Lunas said:i believe silicon breaks down at 90c most chips last till 75-80c so yes i would say the heat is what is frying all these GT's
still it seems pretty hot to me personaly.pxc said:No. The default "core slowdown threshold" temperature on the NV40 is 120C. That's the temperature that those chips are designed to handle.
Xxplosiv said:do you guys think its safe to have my GT clocked at 450 or 460 on the core? ive been playin farcry at 440 with no hiccups or throttling and temps are always below 82 C im wonderin if the reference fan + some arctic silver 5 could handle the GT's molten GPU at those speeds
Bumrush said:I had the same exact problem. Turns out my main power supply cable to my MB had somehow gotten loose and I was undervolting my system.
Shitty clip on the plug maybe? It's fine on my neo platinum. One solution to that would be find a good position and epoxy the sides of the plug to the socket.I(illa Bee said:Had that on my First MSI K8T Neo plat, no matter what i did the PSU MB Plug woudl randomly shut off my system, if i grabed and shook the thing my system wouydl come back on, then when mesureing the 5v line it was like 4.2v, My line idel off a molex is 5.4v, load 5.2v
