your highest AIR COOLED 2500+ clock?
i just wanna see what you guys have achieved on your bartons
i have gotten 2277mhz(shitty, yes i know) but with an NF7-s and a zalman7000Cu i should be able to go a lot higher
That's not all that bad of a overclock. Remember the AMD's run hotter and therefore don't overclock aswell as the P4's. So consider that 2,277mhz pretty damn good.
2415mhz - 11.5x210 with a Zalman flower HS and 120mm fan. ran pretty stable. just installed my wc setup and haven't OCed it yet
I have mine at 2.41 with a thermalright slk900a (clip on) and a 92mm ThermalTake @2800 rpms. MSI Delta ILSR retail motherboard
I get about 17900 on 3dmark 01* and 6100 on 3dmark 03*
200 fsb * 12 Muliplier.
I can post at 2600, boot into windows at anything under that, but it wont stay up, so right now my stable speed is 2410 mhz.
I'm happy with that for now, but when summer time hits, I'm going liquid cooling with another mother board like the Abit nforce board. I'll see if I can't get it up to 2600 stable or higher at that point.
*(around there, can't remember the exact numbers since I'm not at my home computer)
11x220 on an Asus A7N8X-Deluxe... I've gotten higher out of my NF7-S and liquid.
10.5x220=2.31 on 1.8vcore
11x220=2.42 on 1.9vcore
havent tried 2 vcore temp are around 44c/52c
my goalis to hit 2.5 ghz, it may be a little out of reach but with the best HSF retail i think i may be able to hit it
i havent tried to push my barton amd2500 to see how far it will go but im running:
2.2 ghz at 32 Idle and 38 Load with an aerocool, the one that looks like a skyscraper. One time i booted up my system and it was doin 26 idle and 32 load but i havent been able to figure out wtf was going on that time. All i know is i WANT those temps back.
btw ive also got the nf7-s and im only running pc2100, two 256 mb chips in dual channel.
