dBTelos said:Its a good PSU but has crappy Fuhjyyu caps that, in normal situations, won't last longer then a couple years.
davidhammock200 said:It is a great PSU for only $40!![]()
I recommend these as a "Best Bang for the Buck" at $67 & recommend them for up to light SLI.
As to the "cap issue", you need good case cooling,
if the PSU is your only exhaust fan, you will be RMA'ing within 2yrs.
Buy it before the rebate ends.foxnews said:1- what is this cap issue about?
2- is there a fix?
3- is this the only Antec PS that has this isssue? or all Antec PS have this issue?
3- is that a reason why this PS has big rebate?
I hate this; there is always a bad side to a too good deal. I have other 4 fans in my cases: 2x120mm and 2x80mm.
2- is there a fix?
4- is that a reason why this PS has big rebate?
davidhammock200 said:Buy it before the rebate ends.
The PSU's filter caps will fail if over-heated for long peroids of time,
this is not unique to Antec, just make sure you have good case cooling & it should last for years.![]()
foxnews said:all other models from Antec got this issue as well? did they fix it yet?
The newest Trio's & HE's are made by Seasonic & do not use these caps or have this problem.foxnews said:all other models from Antec got this issue as well? did they fix it yet?
Then get a Corsair HX 520W for about $120.foxnews said:I plan to keep this PS for a long time, > 5 years.
should I keep it or return it?
Can you confirm that XCilo fans run faster than Antec's?Oklahoma Wolf said:Actually I'd keep the new one rather than trust a 5 year old CWT made Antec. It'll still last a good year before you need to worry about caps, whereas the 350W has a 4 year head start on developing the problem.
They were, but since then XCilo has changed the 450W,Oklahoma Wolf said:Unfortunately I can't... however if the units you tested were blowing reasonably cool air, they probably were moving more of it than Antec's
My SL350 was always blowing very warm air - it actually lasted a long time (3 years) before needing recapping, but in the end it blew 2 of them - 1 on the 12v rail, 1 on the 5v. The fans barely push any air at all when there's no dust in it. It's now running Panasonic and Chemicon caps in my sister's computer, 100% stable![]()
Depends on case temp & air flow.foxnews said:I don't understand. Antec power spec has a lifespan of 80k hours. if I use 4 hours a day, it would last up to 54 years.
words from you guys seem old or new Antect PS last only a couple years or less. why? does the spec exagerate?
Rabid Badger said:Antec sucks now. I'm not happy about saying it, but that's the way it is. This is what happens when business majors start making decisions that should be left to engineers.![]()
Not at all.foxnews said:This Antec PS has alot of good review on newegg. does that mean something?
MC FLMJIG said:I have bought 2 so far. Extremely quiet and the last one did tend to get a tad warm.
However this one has an 8 pin and the other didn't. Might be some kind of new revision. This one is cool to the touch. Can't complain.
I do want the Liberty or the Cors 520 when things better upa bit. I'm always changing stuff.
Don't worry. I got for cheap and you won't regret.
Not a real review.foxnews said:This review (http://www.pro-clockers.com/reviews.php?id=38&page=6) highly recommended this Antec PS-500.
proclockers said:Talk about stable. Due to the newer ATX 2.0 standard all rails stayed within the 3% range.
_Korruption_ said:
