You think its my card?
thuper
Okay, so I got myself a Sapphire 9800 pro from Newegg about a week ago.
I've been having troubles with it ever since.
I love the graphics and it plays COD and BV just fine. 3DMark03 runs fine too.
It runs games like NFSU and FR2 perfectly for about ten minutes, then the screen goes black and I have to restart the machine.
This happens in Far Cry too (I only have the demo until I work this out), except it doesn't run perfectly.
A couple of days ago VPU Recover started reseting the card every couple of hours even when I wasn't gaming, just browsing or even if the computer was sitting dormant. So I disabled VPU recover. Everythin ran just great, except the Far Cry demo.
I get stuff like this in the game:
More shots:
http://brandicom.com/Files/FarCry0001.jpg
http://brandicom.com/Files/FarCry0003.jpg
http://brandicom.com/Files/FarCry0004.jpg
I turned VPU recover back on and I still have this problem and other games still disappear, but 2D is okay.
What's going on?
Looks like a heating problem.
Pop open the case side panel for a day and play. See how that works out for you.
Yeah, its either the core is too hot, the ram is too hot, or the ram is bad.
what card did you have before this ?
did you clean out the previous drivers real good before installing this one?
using the latest cat 4.6 ?
maybe a format eh?
cooling good inside your case?
got a powerful enough PSU?
also there are known bugs with the FarCry demo that are not in the retail version with ATI cards
In other words, you might have to RMA ASAP ;)
I'd suggest running some non-dx9 stuff like the farb rausch demos and see how they work:
http://www.scene.org/file.php?file=/demos/groups/farb-rausch/fr-025-final2.zip
Try looping this and see if the card still dies. If it doesn't, it may just be a weird driver issue, though its doubtful based on your symptoms. If it does, this is a pretty simple homebrew demo and its likely hardware related. You can try other games like UT, etc, to be sure. The more apps you try the better. If all the fans are working in your case you shouldn't be having heat problems - probably due to a bad connection between the sink and core, if heat turns out to be the problem. From what it sounds like with the VPU recovery problems and 10 minute crashes, heat is probably the likely cause... But again you shouldn't need to do any special cooling to get a card to work at stock speeds, assuming you have a normal case with at least 2 fans in it sucking air through it, so if heat is the problem (you can try putting one of those big box fans blowing on the case with the top off ;) ), I would RMA the card.
What's wrong with what you are seeing in the picture?
No - I would agree - make sure that you have adequate airflow inside your case.
I think I have adequate cooling. I have an intake fan in the middle of the side panel (32cfm), an exaust fan right above the agp slot (27cfm), and an intake fan above that (32cfm).
My power suppy is 400w and by an online calculator my max demand should be 365w.
If it's a heat issue with the card, I'm sending it back. I bought a VGA Silencer and I'm not installing it until I know the card will be good stock.
My old card was an 8500 and I did do a fresh install with the drivers and have even reinstalled them. I've got the Cat 4.5s right now.
What is case temp? Install MBM5 and let us know< i dont think heat is an issue in thisn one..
Ok, so I opened a save game and played, no crapy anywhere and it ran perfectly.
Still, the ram chips got pretty warm and the back of the card over the core was too hot to touch for more than a second or two.
I had this problem too, just built a comp with a 2500, 1gig ram and radeon 9700
Whenever I oc the 2500 to 3200 speeds I would get that. But I found out that it was my ram. So im returning it and getting the ram my friend has whitch worked great.
being a brand new card I would try some different drivers before I condemned the card. Also, what video card did you have in your machine before? Was your old video card working ok?
