All newegg.com, now get your build on.
Using this case http://www.newegg.com/product/product.asp?item=N82E16811133147
burningrave101 said:Whats the purpose in this? If you have $3,000 then why dont YOU build it!
i have to confess, i lol'ed at the processor, $1135....with a $10 instant rebate!!! wow, i'm saving so much money!dchrsf said:
sac_tagg said:Do you need the keyboard/mouse/monitor?
Right off the bat, I'll just tell you what I always tell people who have a huge chuck of change. Go for a route that won't break the bank and has upgradability. Athlon X2 4400+, 2GB RAM, a single 7800GTX/512MB. Later on, you can slap in an FX-60, another 2GB of RAM, and that second GTX.
Not really though. He needs a monitor which probably means a Dell 2405FPW so there went a good chuck of your budget already. Youd be hard-pressed to build a top-of-the-line gaming system from the ground up complete with monitor for $3000. I'll work on something later today, but I gotta go for now.Maniacmous said:If you have $3000 to spend, save most of that money and build a system that'll still kick ass. Actually, if you have time, wait for Socket M2 to come out before you drop major coin on anything, you might get much better performance, and if you don't, you can still get current stuff much cheaper no doubt following its release.
I worded my title wrong I think...Yes, I'm building it myselfS1nF1xx said:Why don't you build it yourself? That's most of the fun right there. If you need help, post your list of components on here. But have some fun with it man.
Doesn't any read the whole topic before posting? He needs the keyboard, mouse, and a good LCD. There goes $850 right there. I wanna see you build a Quad-Opteron system for $2250...jbrukardt said:You're all thinking way to small for three grand. He can have a dual dualcore with sli for that price. Unfortunately the limitation is, the board will be eATX, so that case wont work. If a different case in an option, lemme know and ill spec you out a quad core (split among two cpu's SLI configed box for less than 3 grand)
NulloModo said:Case: Antec P180*
PSU: Antec Truepower II 550W (the price diffence is negligbale)
Mobo: Intel D975XBX $300 (this board will let you OC well, despite being Intel)
Processor: Intel Pentium 4 D 920 $268 (this will OC on stock air to 4.5Ghz garaunteed on that board, higher with better cooling, can go neck and neck with an FX60)
RAM: 2GB Value RAM**
HD: 2 x Western Digital 250GB SE16
Optical: 2x NEC 3550 $88
VidCard: eVGA 7800GTX 256MB***
Soundcard: Onboard****
Keyboard: Whatever basic PS2 or USB keyboard you like (Saitek Eclipse?)
Mouse: Logitech G5/G7
Monitor: Dell 2405FPW
sac_tagg said:Good suggestions, but my changes:
* Antec P180 has much better cooling for the CPU, and you will need it if you are going to overclock it to 4.5GHz+
** DDR2-666 equates out to an operating speed of 333MHz, and the CPU's FSB is at 200MHz. No need for overclocker's RAM if he has 133MHz extra on his RAM
*** Get the 7800GTX 256MB for now, and use eVGA's step-up to get the G71 when the time comes
**** You have dual-core, you will not even notice the few MHz onboard sound does chew up, save yourself $100.
Other than that, good system there.
