Yo, RGB not aligned correctly on lcd
Tengis
Alright, I have this LCD monitor I have been using as a secondary monitor for about 2 weeks. Right down the middle of the monitor the RGB is not aligned correctly and everything seems blurry.
Its a Hyundai ImageQuest l5os
Any proggies or anything I can use to align stuff like that?
Have you tried the easy stuff? Different cable, different video card etc? If that doesn’t change it I’d consider calling tech support, or for an rma if it still under warrantee. Doesn’t sound like anything an adjustment can fix.
Luck
I turned up the refresh rate to 75hz and it fixed the problem. At first I thought the cable was bad, but I didnt have another cable to check it anyways.
