Bleedblue12345
- Nov 1, 2004
So, I have a bfg 7900gs. I decided I wanted to overclock a little more, so I decided to go ahead and voltmod it with stock cooling
. So anyways, long story short is i voltmodded the gpu, but i didn't touch the RAM cause is didnt have ramsinsks or anything. My gpu load temps have gone up frmo 80C to 90C under load. Im not having any artifacting or stability problems, and I cannot fit a new cooler in due to the case beiong small and poorly designed. I was wondering if you guys think i should take the voltmod off, and wait until i can get a better cooler, and how should i go about taking it off if you think i should, since i used a conductive ink pen. Thanks
