Yet another WEIRD video problem.... issue?
NewShockerGuy
So my computer was shutting down earlier in the week... We came to the conclusion that it was the PSU... so I replaced that and the computer stopped rebooting! :) Decided to install a x850 to replace my 9700pro... found that my 2.53ghz p4 system wouldn't start up with it... So I decided to hook another PSU seperatly up to it... ended up frying the card :-(
So now I have an x1600 card in my computer...
This is where it gets REALLY Weird....
I installed the new card, booted it up, got into windows and updated to the newest catalist driver. All seemed fine. Restarted mulitple times...no issues. Today I turned my computer on, my monitor lights up, I see thw windows loading screen, put in my password, it STARTS to go into windows and about 15 seconds when it is IN windows the monitor loses the DVI signal and it displays NO image... I shut the monitor off, turn it back on and still no display.
I restart the comuputer muliple times and get the SAME problem everytime...
So then I hook the monitor up with VGA and DVI, boot it up, everything looks ok.. I start to load windows and it works perfectly fine... I go to switch inputs and it ONLY sees the signal from the DVI.. (which is what I want!)
While in windows, I just pull out the VGA cable, I still get the image on the screen, until I go to restart and what happens is the SAME problem as mentioned above..starts to go into window and the monitor says there is no signal after about 15 seconds into windows itself..
I NEVER had this issue with my 9700pro and it seems like ANY card that I put into the computer it's weird?
Unit's a p4: 2.53ghz
Card is now an ATI radeon 1600
Monitor is a 21" gateway widescreen lcd
Thanks,
-Nigel
I've seen similar problems with a friend's computer. His problem turned out to be that his DVI cable was (most likely) of awful quality, and this was one that came with his monitor. I can't recall what kind of monitor he had, but his system was fairly high end (amd athlon 64 with a 6800 gt). His problems stopped if he used the VGA, and eventually when he bought a new DVI cable.
See if you can find or borrow a DVI cable to test this before you go out and buy a cable. I've never had problems with the DVI cables that came with my Dell 21" widescreen or my Sony 17" LCDs.
