Hello all, I've been researching ssd's for the past few weeks and made up my mind to go with Intel. Just finished going through 20 pages and cannot find what I'm looking for so I thought I'd ask.
- Will using an X25-M by itself then adding that drive into raid -0 cause a performance loss later ?
Thought I read somewhere that if you're going to run raid with these drives, you should do it form the start. If the drive has been used the system will pick up on that. Sorry if I am not explaining this correctly. Talk about confused.
- Can you suggest a 5.25 ->2.5 bay that'll house 4 drives?
I'd eventually like to end up with 4 drives if all goes well. I am aware that you have to leave a certain percentage free to allow for lack of trim. This will be used with the onboard controller on a GA-EP45-UD3P. Thank you in advance for your help.
