Ok guys, cause I know you love reviewing strangers upcoming builds for possible mis-matched parts and bad ideas, I present the one I've been researching for a little bit. First off, a little history.
I'm into gaming, but with my current rig, the newest thing I'm able to play is HoMM5, and juuust barely, with all options turned down. I've stopped playing, it made me too sad. My current rig:
AMD Athlon 1800+
Some old MB, don't remember, doesn't matter anymore
512Megs RAM (nothing special here, either)
GeForce 4200
A 9 year old GamePC case that weighs a ton, has horrible, horrible air flow and layout and no case fans!
Philips 109s
As you can see, it's a sad state of affairs for this gamer. BUT...I'll be getting ahold of some moneys in a few weeks if all goes according to plan, and I'll be wanting a new rig to tinker with over the summer. That, and to make up for all the gaming I've missed in the last couple years. I haven't even played Half Life 2 or Far Cry yet
Oh yeah, and the programs I've been using for my degree have been getting a bit too processor intensive for my current setup...
Here's the build I'm looking at now:
$114 Antec P150 Case
$82 ASRock 939SLI32-eSATA2 Motherboard
$297 Athlon 64 x2 3800+
$25 Arctic Cooling Freezer 64 Pro CPU Fan
$390 Sapphire Radeon X1900XT
$180 G.SKILL Extreme Series 2GB (2 x 1GB) DDR500
$160 Samsung SpinPoint P Series 250GB SATAII x 2 of these
$69 Logitech G15
$330 ViewSonic VX2025WM
$4 Scythe DF series DFS922512L 92mm Case fan
Total: $1650
I'll be using the PS that comes with the P150 case, as I hear it's actually really good, and really quiet. The mouse and DVD-RW will be ripped from my old PC, seeing as how those are the only real salvagable parts.
I want to spend as little as I can, seeing as how I'd like to use whats left of what I'm getting for something else, so I'm setting my absolute max to $1700. I'd like the best performance / price ratio, with gaming in mind. Upgradability too, but as you can see, so far I tend to build a nice rig and then work with it until it's ground into the dust. Also, and this is key, I want it quiet! I know the video card is pretty loud, but all else seem quiet enough, so I'm thinking if the case doesn't quiet it down, then I'll get a different cooler for it. (Regardless, it'll still be quieter than my current jet engine)
As for the MB/CPU combo, here's a question for you all. I chose the ASRock not only because it's a nice value for the price / features, but because it claims to take AM2 as well as 939. Anybody try this? I've read some reviews, and other than saying it can do it, they don't say how well.
Also, here's a possible dumb question... The ASRock says the DDR Standard is DDR400. The ones I have listed are DDR 500. Um...what's going to happen? I think this is just one of those computing basics I completely forgot, or never learned...
Yes, I'm going to try my hand at some OCing too. Haven't done any of that since my old Celeron.
Thanks guys!
AMD Athlon 1800+
GeForce 4200
Philips 109s
$69 Logitech G15
Total: $1650
Thanks guys!
