Yet Another "Rate my Build" thread
OmegaAquinas
Just tried to play the Witcher 2, and it laughed derisively at my current setup--which I realize now was pieced together FIVE YEARS ago. Upside--got good bang for my buck!
So, I'm tossing together a new system to enrich Newegg and power me through another couple of years.Obligatory checklist:
1) What will you be doing with this PC?
Gaming
2) What's your budget?
1500
3) Where do you live?
Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need
Everything :p CPU/RAM/Mobo/VC/PSU/HDDs/Case (why not?).
Possibly reusing optical drives.
6) Will you be overclocking?
Whatever I can get off of air.
20-23"
Now/within a week!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Latest and greatest. RAID/Crossfire/SLI would be nice.
64-bit W7 license already owned.
I've pieced together a wishlist here: https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=16249685
NZXT Phantom PHAN-001BK Black Steel Case
2x SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" (raid 1?)
MSI R6950 Twin Frozr III PE/OC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16
Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost)
Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5" 128GB SATA III (boot/app drive)
ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
How does this look? The mobo is currently out of stock at Newegg; if this build looks good I'll try to source it elsewhere. Conversely, if there's a better board out there I'm all ears!
Solid build! Only thing I would do is up the ram to 8gigs... 4 is prob enough but with lots of stuff open.ive gone past it 2-3 times.. A year or 2 down tge road I imagine il be passing 4gigs alot more often
Last I checked 2 x 4GB = 8gb.
Solid build. Personally I would go with a Corsair or Seasonic power supply. Looks like you want modular, so that would leave the AX or HX line from Corsair or the X series from Seasonic.
750watts is overkill unless you are expecting to do crossfire at a later date.
The C300 is a great drive. The OCZ Vertex 3 uses a newer controller and is faster, but I doubt it would make a much noticeable improvement on load times. The C300 is also tried and tested.
WD Black drives might have the edge now days, but that margin is low as well. Plus those drives sell at a premium.
Good luck on unlocking that 6950 to a 6970. I THINK Newegg is one of the people still selling the MSI cards that will unlock.
Overall solid build. I would just replace the Antec for a Corsair as a personal preference.
Errr excuse my sleepiness last night... Checked the sight just before goin to bed and I thought I saw 2x2gbsticks.... So ya.. Solid build
