I just built a computer. I am pretty familiar with the process and have built several others. When i turn the computer on everything seems to be getting power, but the computer does not POST. show any display, or make any kind of beeping sound. I have gone through several times and checked to make sure everything is plugged in correctly and all of the way. I have taken the ram out and put it back in. Both sticks of ram are in the correct slots for dual channel (4 slots total, tried in both channels and tried with 1 stick in each channel). I have also tried ram from another computer which did not help. I have turned computer off and unplugged power cord and held power button then turned back on. I have pulled the battery off of the mobo and put back in. I have also unplugged everything except for the cpu fan. hdd, and dvd-rom to see if it was a power issue. I do not know what else to try.
Here are the specs (note that it has onboard video)
- ASUS A8N-VM
- 2x512Mb Corsair PC3200 Value
- Seagate 80Gb SATA drive
- DVD-ROM
- 330W PSU
- SI-97A w/92mm Panaflo
Thanks for any help.
- ASUS A8N-VM
- DVD-ROM
- 330W PSU
