Yet another PC advice thread.
Droc
So, stuck in an area dealing with limited retailers. Places like newegg wont ship here....
My local selection is limited.
Im upgrading the base of my old system. I have plenty of HDDs, and an older TT 500watt PSU, P180 case and a new screen. ALl I need is new mobo, cpu, ram and vid card.
Im not into overclocking, but I prolly will OC the CPU when I learn how.
Cash is limited, but I've found close to what Im looking for.
E6400
ASUS P5N32-E SLI Plus motherboard (nForce 680i SLI) <-- going with this because its cheaper then all the other 680i boards in my area.
Ram....ram I just dont know about anymore. Since Im staying with XP, Im just gonna go with 2GB of DDR2.
But what kind? I figure Im going with OCZ, but there are way to many types to choose from.
Is there really a big difference between 6400 and 8500?
Im thinking either:
OCZ 2GB PC2-8500 SLI READY EPP
or
OCZ 2GB PC2-8500 PLAT DUAL XTC EPP
but I dont know the difference between the two.
and I was just going to toss in a mid range PCI-E card till more DX10 cards come into the market.
How much do you plan on OC'ing, once you get into it? DDR2-1066 isn't really needed with an E6400, since its multiplier is 8x.
stock settings:
8 * 266 = 2.13Ghz
the limit on those CPUs is around 3.5Ghz
8 * 438 = 3.5Ghz
so you just need some sticks that could reach DDR2-900 speed... so DDR2-1000 would require no overclock, and some cheap DDR2-800 should be able to reach around 430Mhz. lower stock timings only really helps with overclocking, so don't bother with low latency sticks unless there is no price premium on them.
remember, if you're not oc'ing, your ram will be running at ddr2-533 anyways.
