Yet Another noob asking the same ol' build question
Ric.45
My eyes are bleeding from all the research. I've already gone $100ish over my planned budget to get into dual core cpu and went from a 7600gt to the 7900gs due to what I've read comparing the two.
I'm running Win98 w/XP upgrade. Will probably get Vista in early summer.
This is a surf/rip cd/make mp3/rip dvd/mild gaming rebuild.
Would you check this and tell me what you think?
I haven't found a SLI motherboard that's around the same price so if you know of one.....
I think this will leave me room for minor upgrades in the next year or two if it gets too far behind the power curve. (CPU, vid card, sata hd). I'd like get me thru 2 or 3 years. I'll add another gb of ram in a couple months.
AMD Athlon 64 X2 3800+(65W) AM2 Processor - $135 Newegg http://www.newegg.com/Product/Product.asp?Item=N82E16819103733
Kingston 1GB 240-Pin DDR2 533 (PC2 4200) - $71.99 Newegg http://www.newegg.com/Product/Product.asp?Item=N82E16820144151
BIOSTAR NF4UAM2G Socket AM2 NVIDIA nForce4 Ultra ATX Motherboard - $64.99 Newegg http://www.newegg.com/Product/Product.asp?Item=N82E16813138041
Vantec / iON 2 / 460-Watt / ATX / 120mm Fan / 24-Pin / SATA-Ready / Power Supply - $59.99 TigerDirect http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1407918&CatId=1078
First Choice for video card
XFX PVT71PUDD3 7900GS 256MB 256-bit GDDR3 PCI Express x16 Video Card - $169.99 Newegg
Grand total $501.96 +shipping
Vid Card Comparison http://www.newegg.com/Product/Produ...4130056%2CN82E16814150209,N82E16814150202
Other card choices
XFX PVT71PUDP3 7900GS 256MB 256-bit GDDR3 PCI Express x16 EXTREME Video Card - $149.99 Newegg
EVGA 256-P2-N624-AR 7900GS 256MB 256-bit GDDR3 PCI Express x16 KO Video Card - $154.99 Newegg
XFX GeForce 7900 GS / 256MB DDR3 / SLI / PCI Express / Dual DVI / HDTV / Video Card - $149.99 TigefDirect http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2682785&CatId=1560
I'm hoping to get a flash hardrive by the end of the year. But, I may add an 80gb WD or Seagate sata in a couple months.
Thanks in advance,
Rick
SIGaholics Anonymous ---- Not in THIS lifetime.
I would suggest reading up on the recommended power supplies here in our forum. If you want to expand that rig in the future, that PSU might not hold up so well.
If possible, I would get something faster than DDR2-533 RAM, since you could overclock quite a bit with that setup with some decent 667 or 800 memory.
I'm assuming you have a case/DVD burner/SATA hard drive already? Other than that, things look pretty good. AM2 is a nice option for these kinds of builds, but anything over $700 is starting to get in Core 2 range.
EDIT: oh, and look at ZipZoomFly as a Newegg alternative, they usually have cheaper prices on some items and free shipping is normal.
